Use on of these drive tools on a 1/4” torque wrench for install. Saves this headache in future. Hopefully it isn’t cross threaded.
I can’t imagine cold being issue because only 2 stuck but all others were ok- cold effects all of them.
OR, You could warm it up and those 2 come out easy. Heat gun? Small butane torch? Even a fireplace lighter with the flame on the bolt head?
Steel bolt, aluminum transmission body. There has to be some special goo to stop the galvanic corrosion that is not going to let the bolts come out on accident.
Removing and cleaning the bolts and bolt holes every 30,000 miles would fix this issue but slackers like me don’t always do it.
Most of those bolts are through hole type in the tranny. you might try squirting some PB blaster over the top side of the threads where the end is barley sticking through. drive it and keep squirting daily. when you get ready to pull the bolts give the bolt head a good couple smacks with a flat punch or the extractor you plan to use. that might give you some luck getting them out.
is that pan and bolts OEM or something aftermarket? only reason I ask is the design of the pan looks aftermarket where cheap grade 2 steel was used making the bolts and possibly why your seeing the heads strip. when you got new replacement bolts, make sure they are grade 5 and not made in china!
something that frightens me too is the use of MAP gas on the aluminum, if that pan is aluminum, be very careful. I'm sure you know that already, but my experience using MAP gas is it gets much hotter a LOT faster. could distort the aluminum mating surfaces or worse cause a crack.
@Big T when you do get the pan pulled, I am curious what brand or markings are on it. I like the contour of it and the fact it has a drain and port for a temp sender! I have been thinking about having a gauge in the cab for trans temp. that would be an ideal place for a sender.![]()
Yup! that I like tooI will look. Did you see that it has cooling fins?![]()
The pan is manufactured by PML. They currently run about $285. Recognized it right off the bat as soon as the pic was posted.
Pressure port on the side of the transmission is where Mine is plugged into, or, it must be. It shore aint plumbed into the pan.I was actually wondering how hard it is to do a temp sensor on the tranny.
