dbrannon79
I'm getting there!
Here ya go…. Watch the tensioner and belt start moving towards the inside of the pulley at 1:18. I was pouring from a water bottle
Are you able to grind a slot in the head and wedge a flat screwdriver in there like those craftsman ones that have the square shank to put a wrench on to help turn?
This might work.
if you have an impact screw driver (type you use a hammer on) , try using a chisel point bit. I've had to grind a flat git into a point before. that might be able to dig into the head and grip it without having to cut a slot. might be just enough to break it loose and thread it out.
That's a whole lot of smoke! how cold was it when you filmed your video? that could definetly be an injector leaking. does it still smoke after warmed up and then let sit for maybe 30 minutes to an hour?Video of my ‘99 on cold start up at 40 F. Starts instantly, but takes a bit for the white smoke to clear up.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
This is what the internet says:
1. White smoke on a cold start, and then it disappears as the engine warms up
This is very common. It will often happen at startup in cold weather with lower compression engines. As you start running the engine at idle (around 650 or 750 rpm), you will achieve a more effective compression ratio, and the smoke clears. White smoke has a lot to do with the temperature in the combustion chamber.
If the smoke is really just a puff, there is not much to worry about. Especially if it has been sitting, it could just be built up condensation.
If it lasts a few minutes after the engine is started and there is a rich diesel smell,they may be some cause for concern. Some of the likely causes include,
Remember, if you have an older engine with really low compression and bad timing or low injection pressure, you are more likely to have white smoke.
- Faulty injectors - stuck open.
- Worn piston rings or cylinder glazing
- If equipped with glow plugs, could be faulty plugs or module.
So I've replaced Glow Plugs and the harness. Injectors soon to be replaced as it's time.
I poked remanned Bosch units, from Oreilly, into My 6.5 and it has a small puff of white smoke on startup.
The colder the temps, the mor smoke it puffs out.
That lasts for several seconds then its down to just exhaust.
I even advanced the timing a notch or ten. I thingk it was -.43 and now it is -1.53 or some such. It still blows its puffa white smoke.
I’ll live just fine I figure.
That would be great. Be looking forwards to that.My wife loves to do road trips for her geocaching. She has a goal to find a geocache in every county of Montana. So we’ll probably make a road trip out your way and return the IP.
Temp was 40 F.
Letting it sit 30 after warm-up, not much smoke. Just a light puff on start-up.
I’m thinking injectors leaking. I have a new of Bosch from Leroy that I just bought.
