MrMarty51
I`ll check that out. Never heard of those before.
If I remember correctly its a poly-graphite blend bushing this is why I use them.Look at Energy Suspension Poly bushings in squeak free black. Make a world of difference in getting rid of GM's MUSHY handling feeling.
took mine in with 260K and was expecting to pay a lot but nothing was wore out. all it needed was an alignment. drives straight and tires are wearing even.Took the 2000 K3500 to the alignment shop.....
................. If that is all that is the matter after 245,000 miles, I`d say I`m getting off real reasonable. Tie rods, lower ball joints, drag link, pitman arm is all good............ LOL
Sorry, I could not clicky the like button on that post. That's just too bad.yeah. i hear ya.
mine is at the trans shop: pump is busted and 2 ears are broken. will salvage parts from the old to get it fixed. pissed.
with what?replaced oil cooler lines
One more 'while I'm in here changing the water pump' project done...Injectors installed, lines tightened and return lines installed. These things never get any easier to do. Seems a different combination of tools, extensions, angles, wrenches etc. is required for each one. Easiest thing was installing the caps w/ clips on number 7 & 8. Go figure.
Concur on #4, I can't recall how I got the @#$%^& thing out! #3 was easy as I had a clear straight shot at it with about 12" of extensions. Number 2 left the copper crush washer in the hole. Came out easy enough. Discovered the nut on the #2 glow plug just spins on the plug. Plug is fine but, it's going to get entertaining should I need to replace it someday. Guess the welder I was given (which I have no idea how to use) may come in handy yet. Guess I'll keep it 'for just such an emergency."3 and 4 are the biatch.
I am so pleased that mine is running fine for now.
More rust work.
Knowing the right fender had issues when I bought it, I picked up a replacement fender for when I got around to addressing it. The inner fender had already been removed so I figured it was time. Besides, having it out it will make replacing the fan, radiator, hoses, glow plug wires, starter cable…I’m getting depressed at the punch list… back to fender work.
Yesterday I started removing the fender flare not realizing that it is bolted on through the fender as well as screwed in along the fender well edge. The replacement fender isn’t drilled for this so, one step forward, two back. At least the replacement color matched the lower part of the Burb so I removed the molding, sanded and got it primed.
Today I wanted to scuff and spray the replacement but, we had snow flurries being blown sideways so, instead, I removed the old fender and got to the last couple of nuts holding the flare in place. I guess I could spray it with some Rustolium, add some bondo and just put the flare back on…nah.
The sun came out so I hurriedly did the prep for the color matching Rattle Can work on the replacement fender and got it done before the rain/snow started again. Reflection makes it look like overspray on the lower half. It will do until I get the flare holes marked and drilled. Then I’ll scuff it again and shoot it with ‘real’ paint later.
I didn’t put in the turbo heat shield back after I replaced the injectors the other day so, figured I'd do it today as well. It was pretty nasty from, I’m guessing, exhaust leaks at the turbo/exhaust manifold.
So I hit it with a wire wheel on both sides and then the DA sander with 150 and 220 on the outside. Final sanding was 320 to get rid of the DA Swirles. Shot it with VHT engine paint, black on the inside, silver outside. Yeah, I’m fussy. It will probably only survive a week before it boils off.
Clouds coming in, time to quit and go hold down the couch. Cheers.
