Exactly. I have a Friend that got right back to it after back surgery and now he is very crippled@MrMarty51 HEY follow dr orders man! Who does any of it if you take yourself out for an extra year?
@Paveltolz keeping the wifey happy is always the smartest choice.
Maybe you just need some racing stripes on the hood this time?
Why replace the old column with another old column…On my rig, I have been noticing lately that my column shifter had been getting loose and sloppy. it almost feels like something is about to break in there. I had to replace the entire column when I bought the truck due to the shifter was broken. got the one in it now from the pick a part yard. I hope it doesn't need parts that would cause the need for another junk yard column again!
if that is the case, I might try looking into a newer style column. I have heard that the ones from the 2010 or 2015 would fit. that would be a nice addition with the looks of the steering wheel and what not. Though the last time I was at the pick a part yard, they are starting to charge you for each individual piece. not for assemblies anymore. I would assume they'd break down the whole column to charge for the wheel + cap +column + shifter..... might be better off dissecting a column out there just for the pieces I need leaving the remaining for them to scrap and loose money like I see everyone else out there doing instead of taking the whole thing.
On my ‘94 Suburban, there is a plastic collar to which the cable for the shift indicator attachés. It broke its attachment to the shift hub so was not rotating with it and you could not “see” what gear you were in. I did an interim fix of attaching it to the shift hub with duct tape. I say interim because it’s off one gear notch, so R is really drive.I didn't know anyone rebuilds them! the issue is getting the parts. when I had to replace it the frist time. there was a piece of aluminum in there on the shifter linkage that I couldn't find as a replacement part.
I don’t know. It’s probably on N when in OD.Wouldn't that be off two notches, or do you have the very rare no Neutral automatic transmission with the P-R-OD-D-2-1 pattern?
Indicator has a cable attached to a plastic hub on the column. Cable wraps around the hub when rotating clock-wise, spring pulls it back when going counter clock-wise. But this plastic hub is supposed to lock into the metal shifter hub on the column.Thats what's odd on mine. the indicator seems to move and stay inline with the cable but the lever has a LOT of slop. the indicator doesn't move with the handle until you feel the linkage moving in there. occasionally it also feels kinda like something is rough in there when I shift from park to drive or back the other way as if something in the column is grinding on jagged aluminum if that makes any sense.
I need to get in there and look at it. just have been very lazy about it lol.
I need to repair the engine bay lamp in my ‘99. Where did you get these?Since the LED tail lights were malfunctioning, half lit and reverse lamp circuit dead on one side I got out the faded old OEM units and did a 'headlight restoration' on them. SuperbrightLED.com supplied the 1156 and 57 bulbs along with a shorter 1156 for the engine bay lamp and an even shorter one for the under-hood reel lamp which I went over the other night to restore functionality.
