Matt Bachand
Depends on the 6.5
Let me see what I can come up with. I will have to get back to you tomorrow. Are you set on a Racor filter? I can get a Wix set up or Perma Cool that is 10 micron also and the replacement spin on filters for them are available at any auto parts. I think the Raycor will be harded to find??
Also, with my LP bypass fittings If you are runnig a different LP/filter it not a problem, just keep your stock LP for emergency. You would just remove my fittings and put the stock LP right back in the stock location, plug it in and go.
Well, taking stock pump and replacing my dead stock pump that transfers fuel from my rear tank into my main tank, ... I have to drop the rear tank and clean it too, replace that pump, then drop the front tank clean it and find out what is causing me out of fuel 11 gallons deep in my 22 gallon tank.
While I have the tank dropped, I am eliminating that damn sock altogether, and installing a prefilter.
Since I need to buy another LP anyhow, I might as well buy a walbro as they are same priced, and is rated to pull thru a filter, as well as better overall performance for the same price.
I do not have my heart set on any fuel filter at all, but I do want one with a clear bottom that separates water also.
I am interesrted in this very much leroy, but it may be a month or 2 before purchase as I need to get inspection sticker which may require exhaust, and WILL require tires. I already have 2 new tires, and think I found another 4 on c-list.
I appreciate your fast efforts leroy, but I don't want to mislead you that I am ready to buy right now. I can promise your efforts wont be wasted as I will do this in the next couple months, but can't right now.
Thanks again.
