alphadeltaromeo
Diesel Enthusiast
Sorry for the slow response. I used the Felpro kit and it was mostly metal. I really have no idea on the cometic gaskets.
Andy,
Now that the Suburban is running again, are you having the transmission error still?
Hmmmm....missing ground ??One thing to note is that I am missing the ground on the drivers side rear of block on head. There wasn't a ground there.
I don't remember having a ground on the drivers side
x2
Can you also check to see what the warm idle desired timing is? If its really low like 5 degrees that could be an issue too.
