alphadeltaromeo
Diesel Enthusiast
Good point. I believe what interested me was that it was one "tool" that helped in diagnosing a potential issue. Just found the vid to be informative
Good to see your back on the road again Andy! I wished you lived closer I would rent your boys for a few days as I just found out today that both the head gasket and water pump are leaking. The truck has been parked a lot lately as it is not our daily driver any more. Had to take it for a good high way run and it did the HG and water pump in.:mad2: Just looking at it it looks like it would be hard enough just getting the heads off let alone getting them back on with ARP studs (which I would go with) I might just pull the engine and give it all the attention it might need gasket wise, clean her up and maybe spoil it with a bit of paint.
If any one has done this on a 2500 4x4, is it fairly easy to pull the engine and leave the auto transmission and transfer case in place?
Flushing the condensor the same way is a good idea too.
