Time for some rust repair on the Tahoe.
Driver side cargo area floor is done.
Next I fixed the rear frame crossmember that was rusted through from the foam between the crossmember and gas tank trapping moisture.
6FFF34CC-9413-4431-82E8-4B891612F466.jpeg5F97F689-8B82-44E9-AE61-DC5D1AF4CE2E.jpegB658BD48-AB4C-4976-B5CD-5969561342DE.jpegDD3A4E7C-1044-480F-9210-56F54ECA6E29.jpeg
Now I’m working on the passenger side. The damage is spread out a lot less, but it went a bit deeper because the crossmember was also roached. So next I’ll be rebuilding that and then fixing the floor.
E25B2660-58DB-4F5D-AF9D-3C40C6A0465C.jpegBC8E9C4D-534C-4243-AA76-5A2009BE3EAB.jpeg134B0E21-3ED0-43F3-A1AC-9ACF47CADEDA.jpeg
I got the passenger side fixed today. First I made a new patch section for the crossmember.
85DA7798-5587-49E6-86B3-A5CFAB3BD830.jpeg1041BF71-6E8B-492B-914B-5D1D95D9CD1E.jpeg3349F6CF-9ADF-478F-BE5F-F5E51870AD45.jpeg93EF9BE7-047C-4A9D-9582-83A264F26295.jpeg
Once it was welded in I painted Rust Seal on the internal surfaces for future protection. No picture of the paint unfortunately.
DE340BAC-4AAA-45BC-BF78-96C259938AD0.jpeg7015A2AD-891C-4636-A7B6-1EE8DB7A1864.jpegD684D219-5EC8-45A4-B9A0-A653AD596938.jpeg
I also patched a small section of floor further up.
Then I made patch panels for the floor.
Here are views all around the repair.
292BA3F3-F2CE-4D4E-B5E3-A92D4309EC53.jpegC0A8CF10-07CE-4CA0-8185-B6DFA9CC43F2.jpeg4250B54E-7B80-4C93-AC56-4C9091C19A73.jpegFC5F35A4-7EA2-4BAA-A38B-E91CCD345F90.jpeg
Unfortunately while admiring the finished job I found more pin holes in the floor. I thought I was done, but it looks like I have another week to go. Ugh.
Finally wrapped up floor repairs this weekend. All of the patches are complete.
1BEF7431-FBBD-40DE-9F1F-9E71102BB197.jpegFB59F806-0EAA-44E7-A767-7DE097DE8281.jpeg86EEFB62-706F-40E3-8940-15814E000BDB.jpeg
Today I applied the KBS Rust Blast to the underside just to make sure that the rust was taken care of and the fresh sheet metal was etched for optimal paint adhesion. I had 1 gallon and 1 quart of the product, but I wished I had 2 gallons - you are supposed to keep the product wet while it’s working and I didn’t have any left to keep misting on it. So I misted a little water on it for a few minutes, but then I started rinsing it with water after that. I probably got 30 minutes of soaking time, but I really wanted to do it for 60 minutes. Oh well, you can sure see the zinc phosphate coating that it deposited on the metal.
9927C5F9-8233-4486-A80D-AC6C03319DF6.jpeg02837E51-7FCA-4D16-916A-C99105BF00B9.jpeg64233207-EE72-4815-A84D-B9F6EA25308F.jpegE6DC62EE-53AB-48AE-B535-AD4E34539A5A.jpeg82CCCC82-3274-4A57-A149-6D3D8E096D6E.jpeg
This week is prep work so I can paint the underside next Saturday. That will be a big step!
Tonight I did some axle prep. A couple of the brake line retainer tabs had broken off so the fix I came up with was to grind them off and weld tapped blocks to the axle. I bought some stainless steel tabs that will clamp the brake line down to the blocks. I think it will look kind of trick when it goes back together.
6E871D96-4B3E-4B47-8940-0E37ACF09F43.jpeg652C742F-2E94-4A93-9A4D-928E388AA947.jpeg624FE8F1-4B95-46C6-A1C5-125B4B616C24.jpeg
