540s10
I almost bit the Kojo Bullet today.... I'm itchin hard.... wont be long.
you should do it, and test it on mine
you should do it, and test it on mine![]()
I have measured 3 suburbans with chip and stock style liftpump. in everyone fuel pressure dropped below zero when accelarating at full throttle.
Meter was connected to water drain valve so there is still some restrictions after that when fuel is going to ip, but ftb takes care of them, and better lift pump (i prefer walbro) should take care fuel coming to filter.
Stewart Warner makes a standard sized fuel gauge with electric sender. Its what I use. It was only 80 bux or so.
http://www.carshopinc.com/product_info.php/products_id/73673/114212
Absolutely perfect layout for the 6.5. Details when you need it, and ballpark highpressure when you don't.
matt did you have to buy a sender with that or is that for the whole deal every thing needed to make it work?
if you can still see it good enough to read it oh well eventally im going to buy all matching autometers but dont have that kinda money right now and really want a fuel pressure gauge
