Slim Shady
DEATH BEFORE DISHONOR
- Messages
- 1,523
- Reaction score
- 32
DO you want me to stop making comments about the posts you make? And would rather not have me suggest anything?
View attachment 29479View attachment 29480View attachment 29481
Here is some pics of the start of the install.
The good is it lines up with the intake,but had to shim upper 1/4inch. I cut the V-band portion off the turbo, and had to trim 1/4 inch off the upper intake.
Although I plan on making a custom upper in the future anyways, this was for people contemplating this swap with no welding/limited fab skills.
The oil return line looks like it was made for it, no mods neccasary, and the oil feed line no mods either except tapping for GM fitting.
The bad,[if you can't fab] is the receiver dryer will have to be move 2.5inches to the right so I can utilize the 3 1/2 inch D/P fitting.
I will have to locate a receiver dryer repair kit so I can lengthen the pipe and relocate to the position I want it. If anyone knows where to get one to cut down on my search time it would be appreciated.
Otherwise i will continue to update as I progress.
Then what was the christian comment for. I'm a christian also and don't throw that in you face.
And thanks for the advise, you're right about the gap, that was just put on for mockup to show that it lines up and doesn't sit to far foward or back.
here is a video of a 6.2l with the detroit style blower... so it looks like it can be done....:rolleyes5:
http://butty-run.com/startup.mp4
oops the link is gone, but here is a pick...
http://www.dieselplace.com/forum/showpost.php?p=3905637&postcount=162
it is on the other site, and the video was off it runnung, but it is a little over the top for my likings... we are thinking eaton m-112....
mmmm, new... looks awesome, hows the quality look so far?
we bought and parted a 1986 3500 1 ton dually 4x4 in the spring.... heavy duty life it had, 10 ft snowplow on the front, 8ft side blade, and a 2 yard sander in the dumper box... 6.2l NA, one of the cleanest innerds i ever seed... and not one crack in the mains... still original print-o-seal head gaskets... 225000 km onner..... our block for our build for sure.... anyways, long story short, it had extra cast aluminum pulleys on it from fisher... thinkin the three extra belt will work good to spin our eaton m-112...:thumbsup:
sounds like a good find! My motor with 101K on it had ridges in the cylinders you could catch your fingernail on and a crack in main journal #2!![]()
rob...wouldn't you like my Peninsular upper...
could look in the Four seasons book tommorow . I know what you are talking about but I don't think they made them for that. They made those repair kits with the compression fitting for the OBS Harrison boxes. I'll look though. I have an '06 catalog.
I will probably use the GM4 for now. My only issue is the way the ex flange comes off it gets ugly trying to squeeze a downpipe in. Alot of guys run the exhaust on the outside of the frame or deal with a custom made DP hitting the cab. I do not want a bodylift so I'll figure something out. The reason why the holset interested me was I was looking for the same low end grunt the GM4 has but with a more flexible ex flange angle to work with. A gm5 or higher or ATT will probably not be what I am looking for. This truck will not tow save for draggin my camper home in an emergency and I want low end out of the hole for off road use and snow plowing. To be honest I wasn't even going to screw with the turbo until spring but the exhaust system is literally one bump from falling completely off the truck and I am not spending money to fix it knowing it will be worthless on a turbo truck. I will run the race next weekend N/A and then the turboswap will begin. I will start a new thread on it when I do. In the meantime...drool boys drool...this was a gift from a former 6.5 er...wanna talk about flow....Kenny. Did you ever figure out what turbo was the best for your project?
Will possibly be in your neck of the woods in October, might be a chance to meet in person.
