buddy
Active Member
It should just be less of an issue with our 6.5, because we dont go from 6000rpm to no airflow. We go from 3000rpm to 1000rpm when we get off the pedal with full flow, no air throttle and large displacement so good amount of air to flow. Its more likely with someone running a turbo with too large of a compressor with a small exhaust housing and wheel (higher shaft speed and backpressure).
The larger the inducer the more likely to have surging, so I can see why a 65mm inducer would have issues, especially if they did not up the exducer side. Seeing as Ive run the GM4 past 30psi without issues I dont think we will have a problem. It has a 53mm inducer with a 75mm exducer, thats a trim value of 50. Up to 60mm should not be an issue for us, especially when you maintain the same trim value, like with an 85mm exducer to get a trim value of 50. In general the higher the trim value the more it will "flow". The larger the inducer the larger "bite" of air it takes at a time.
A lot of those guys that can cause surge seem to do it for fun sometimes which is not good.
Dodge also had HX40s with that silencer ring in it, that actually covers up the "anti-surge" part of the compressor housing. I am not sure how well it works, but I would take out that smooth ring thing they put in the inlet.
