Acesneights1
You'll need to use your old injection pump, and/or have it rebuilt (or at least checked out). I'm pretty sure the military version is 24v unit. If you do get a pump with the new motor, you can probably unload it on steel soldiers (another forum for CUCV owners) and make a few bucks back.
Likewise. you'll need to use all your original 12v accys: alt, starter, GP controller, etc. Swap in your vacuum pump if the new motor doesn't have one.
Injectors and lines should be a direct swap. Both engines will be coarse thread unless someone put '82 heads on your old motor. If your injectors have 80k+ on them, you might want to at least have them checked before reinstalling them, if not putting new ones in.
Can't recall if the fan clutch on those is the same or not. If in doubt, use your old one or replace it with a new unit of the same (civilian) style.
No other advantage to the military motor aside from lack of EGR, as far as I'm aware.
That is NOT correct. You need to identify what the motor came out of first. If it came out of a CUCV , everything BUT the starter is 12v. ONly Humvee engines had 24v glows and ESO. And the ESO can be changed on truck. No need to replace IP. In fact I would leave the Mil spec one on unless there is something wrong with it.They are slightly turned up AFAIK. Motor mounts are the same. Coarse thread is pre 82 red block. 84+ will be fine thread and interchangable. The motor shoud be drop in barring whatever accessories you need. CUCV motors have a vac pump as well. It is used for the kickdown on the trans. If you have a TH700r4 then you will need the vac pump off the old motor as it has ESS in it. CUCV ones do not. I am not sure what years needed those. My 91 Jimmy had it. My 90 Burb does not but has a TH400.
It is a J code motor. No emmisions....
