malibu795
misspleelleer..........
no, no sleeper i find that the extra ~500-600lb in cargo capacity allows me to make more money then i would save haveing then having not to stay in a hotel room
The expanded metal decks are junk, frame bends and cracks, axles and brakes needed work every 15k miles from the factory, wiring never lasted more than a winter because they never sealed anything, just used scotch connectors, paint was like they never used primer, gave a 5 year old a rattle can and said have at it. Over time (5 years) the frame will rot from the inside out because of the tube steel.
My PJ was I-beam construction, powder coat paint, all the connections were sealed, water tight, LED lights from the factory, 8k dexter axles with greaseable suspension. Just happier with it overall. The trailer I tow now is basically the same design as the pj but longer trailer and dovetail.
What are you guys hauling?
the way i read the rules IAW the FMCSR then tow vehicle needs to be plated for then entire vehicle. according to the FMCSR when a tow vehicle and towed vehicle are are considered one vehicle.Adam, I am sure I have asked before, but does stamped weight make any difference, or is just what you are licensed for? I get mixed opinions all over.
I think to play it safe, if I do get a new trailer, getting it stamped for 14K so I can use up to my 11K rated 99 C3500 (non HD) chassis cab rated for 11K (and if a duramax 2wd chassis cab comes into my future, 11,400) on it and still be stamped for under 26K. but I have heard some states are stopping folks over 10K. If the DOT gets too bad, its gonna be time for a monster bumper pull behind the burb.![]()
