142 bar = 2060 psi
150 bar = 2175 psi
If their tolerance is 75psi up or down to get a range of 2100-2250 psi I wouldnt use that shop or specify a tolerance like 25psi up and down.
I got the Wife's 95 set at 2200,93 stock LP,never see below 2 psi fuel press at the IP inlet WOT, over 50.000 km on the hi pop squirts.Dave, how you like that pop pressure, is idle any different these days with the 2250psi pop? Just need to have a nice 15psi lift pump and FTB to keep the fuel supply to the IP and those injectors.
Maybe thats what happens with poor nozzles, high boost and high cylinder pressures with low injector pop pressures, or even using ether and crap to get it started.
Makes me more skeptical about those AC Delco Bosch / India squirts I asked you about......
I would think those would be better than the cheap crappy ones from ebay. There is a seller that is selling chineese injectors on ebay for $150 /set. He claims he tests pop pressure. No warranty. A seller from Georgia and several others sell the "097" injectors like i threw in the scrap barrel.
