Slim Shady
DEATH BEFORE DISHONOR
- Messages
- 1,523
- Reaction score
- 32
I was wondering about rebuild kits is anything going to be available?
What kind of rebuild kits??
Well I've rebuilt the stock turbo twice so I was thinking the kit might be similar. Assuming that one is available.
I got embarassed because Matuva had a turbo shipped all the way to New Caledonia and installed and mine is still sitting on the Dining Room table. Damn the weather. After I recover from shoulder surgery the weather will be better and on it will go.
If you want a hand, give me a shout when you go to install it.
I am in Wilmington. I'm still relatively new to diesels, but definately not new to turbos or working under hoods.
I'd also like to see what this turbo involves. I have a few things to do to mine first, but will definately be looking for a turbo upgrade eventually.
Well, I don't tow often either.
I choose that ATT after reviewing all the job done by Tim and Dennis for testing and improving this turbo.
I'm not a racer too, but really, I appreciate a lot having the truck responding faster and easier at low rpms now.
About the sound, the ATT seems to be a bit more "quiet" than my previous GM-5, whistling less, though I can still hear it. But, if you look for nice rumble, believe me, you won't be disappointed.
I have a straight pipe with a silverline resonator, and most of guys think now I get a gasser.
It's hard to find words to describe the rumble : louder, more powerful, but at the same time not agressive. You have the feeling that this a the purr of a beast, feeling that behind this rumble is hidden a good source of power and torque.
Never heard a tiger purring, but that should be pretty close ):h
I gave my turbo the nick name of "Woa" : each time I start my engine for people to listen, they say Woa!, open the hood and show the turbo, Woa! again, take them for a drive, and Woa!
you mean standard tranny & rear end?You standard shift Mutava?
BTW, awesome pix in your garage.
not sure on "off the line", due to the fact I just changed to 373's. HOWEVER---I told dennis, on my rig when I hit about 2100 rpm's this turbo pulls smooth and very hard over the gm. this is truck only-have load going north soon and I'm anxious to see how she pulls loaded. normal cruising egt's have dropped about 50 degrees averaged. best mod I've done so far.
I am looking forward to hearing the results from your pull. When I pulled the 20,000 LB load it was nice and smooth,the engine came alive after a nice long pull, you are going to like the sound of the exhaust when pulling.
The exhaust definitely has a throaty rumble.Leo
