Mudbath
Old Smoky
Where is the best place to buy a quality reman IP here in Canada. I am having problems with TDC Timeset and TDC Learn on my truck and it is looking like the pump is the problem. The TSM is broken and needs to be replaced at a cost of about $160.00 but when I took the TSM off and tried to rotate the shaft that it is controlling I could barely get it to move (a few degrees back and forth, so it isn't seized). I do not know if that is normal without the pump actually turning, nothing to compare it with. If someone has an old pump off of the engine and could check that for me, maybe just the TSM needs to be replaced and not the whole IP. It is a bare to start cold and smoke like a banchee, but is fine once warmed up.
See my other thread for more details
http://www.thetruckstop.us/forum/showthread.php?30673-Timing-issues-Help
