DZZ71
"Living The 6.5 Dream"
thats a dam good trade
That's what i thought!
Don't sweat the 506 block, just don't let your temps go over 210 and you shouldn't have a problem. If you're pulling hard and they are climbing above 210, do the fan clutch mod until it engages before 210. Before these forums and the pro's knowhow, GM stamped the danger zoen at 260 on the gauge. Well, at 260 blocks alraedy toasted... no time to worry. Start worrying at 210 and you'll be fine.
Nice work.
Sure makes things look easy with the fenders and grille and radiators removed.
No worries. I am not offended. Some of the issues you are describing were there when I first got the truck and I didn't really put in any time to fix them.
I will try to help you out here - the wire hanging in the fuse box is a power wire (I believe for the GP override, but can't remember off the top of my head). It is bare and was connected to an 'add a fuse' (which I removed and used on another vehicle - you can get them at Canadian Tire). I am not sure about the chopped wires. I never chopped any wires. Previous owner perhaps? Maybe even when the command start was installed?
I always cover my soldered wires either with heatshrink or tape. Perhaps the tape didn't stick properly? Can't tell without seeing it. What wires would have been soldered on that relay anyways? As far as I remember, they were all full lengths and the crimp on ends?
As for the tangled wires - I ran all of my wires to the engine compartment through the hole for the throttle cable - I admit, it was a bit of a disaster, I was going to grab some grommets and drill holes through the firewall and do it right, but running them that way worked for the time being...
I have a hard time believing that the lift pump was bad. I tested it before I had headed out on that day I blew the truck up and it tested just fine. It was a Heath HO pump that was less than a year old.
There are always hidden things with old vehicles....I had to spend quite a few hours and dollars fixing things on that sled you traded me too![]()
I re-read Chad's post. The LP is good.
Chad - the OPS in my engine was a brand new AC Delco unit bought from my local dealership. There are no chinese sensors on that rig....just Delco. You will want to check the wiring harness....like you said, you must have pinched something cause it was working fine before...
It sounds like you must have missed a ground wire, or screwed something up during the engine removal. There were absolutely zero electrical problems with the truck.
You have to download the software I mentioned to you on to a laptop. Hook the scanner up to the laptop and run the Scantech program.
There should have been grounds from the frame to the engine (braided one by the starter), from the battery to the engine, from the ECM to the engine (rear passenger side of intake - by the trans dipstick), from the battery to the frame (passenger side battery).
