chrisk1500
Whoever you talked to is wrong.....wasn't Lyndon was it?
You need to resolve the coolant temp sensor issue. It is causing the GP light, the not shifting into OD, the noisy engine, and the smoke....
When the ECM believes that it is cold, it tries to go easy on the engine. Fix the sensor issue and your problems will disappear.
There is absolutely nothing wrong with the PMD that was on the truck when I gave it to you.
Before changing the harness, use a paperclip instead of plugging in the sensor (jump the connector) and see what happens...
Chad - if that made no difference, then there may be bad wiring to the connector...strip the wire loom back until you find it....
The joys of owning/buying a used truck
