SS FORCE
Active Member
Worked on the hood today and drilled out the louver panels. Not as bad a job as the fender vent so these could be re-used. I pulled the ratty hoodliner that has seen better days. I'll have to consider an alternate replacement as the fiberglass OEM unit took quite a beating with all the air coming in and out of louvers as well as water etc. So, cleaned it all up, got all the gack off of it. Removed all the adhesive on the front edge left over from holding on various bug deflectors, coated all the bare metal underneath with primer/rust inhibitor so the holes from other bug deflectors didn't rust out. After it all dried I turned it over to start cleaning and removing the paint on top and while doing so it fell off the saw horse and stove in the front corner. It isn't bad but I doubt it is one of those things that can be made right. I know I don't have the skill sets and replacements can be found for cheap in the strip yards that it isn't worth the time. I'd say two steps forward and three back except I have a nice hood on my 95 Tahoe...
So, I'll strip the paint off the top of the old hood as planned, repaint it as best I can, repaint the old louvers and reinstall them.
The Tahoe's hood is pretty much unblemished save for a couple of wear points from the current bug deflector so I'll feather those out and cut the louver holes out prior to paint. I have new hood louvers on the way that will be anodized and clear powder coated so they don't peal like the first set and so I'll have a nice 'new' setup for the truck when the time comes.
Dynamat sells a sound dampening solution for hoods that is head resistant. Might look a little cleaner than the oem fiberglass stuff and offer some sound deadening. Looking great Paul. I've sure missed a lot of your projects on here. Will be watching this thread much more closely. If the painting on the heat side of the turbo housing and the exhaust manifolds doesn't hold I know a place in town that has a high temp powdercoating. I looked into it for my Holset but im far from having the Cash to do anything. Or the time for that matter. Sure looks like a lot of fun. Cant wait to dive into my own rig. How did you put it? A case of forumitis?
