Ok so this has been a fun week of finding all sorts of clearance issues. I finally got the tie rod installed. First thing I noticed was I had a hard time clearing the leaf springs pulling it in. And the front end is only finger tight. I'm using D44 knuckles that run the tie rod on top. Also the ORD tie rod sits higher due to its design. So I knew it would be a close fit. Once I tightened up the ball joints and all of the steering arms the clearance got worse. On full lock my tie rod rubs the leaf spring slightly!! I'm a little disappointed about this. I ordered everything from ORD even the leaf springs. I'm running the correct knuckles they recommend. And I'm still having clearance issues WTF!
After I rolled it over for a few I came to a very easy solution. I'm going to add a short leaf that will give me the clearance I need. Luckily I have a set of practically new add a leaf for the 52" springs. They are 5/8" thick so I cut them down to 8". That will give me the tie rod clearance I need. Just need a set of longer center bolts for the springs and I can finish that up. So unfortunately the track bar has to wait till I correct this issue.
Then I ran into another clearance issue. I could get full steering lock turning left. But the tie rod hit the diff cover going right. And it was a noticable amount of steering loss. So this diff cover is not going to work.
Finding a plate steel cover for the front 10 bolt was far and few between. This was really the only one I found. And it's been discontinued. But I found one other place that makes one with a option to order it unwelded. That will be very helpful so I can custom fit it to clear the tie rod. It's still going to be tight but its possible. Here's a pic of the stock cover for a clearance reference.
Then I got the sway bar temporally clamped in place. TK 1 racing makes a 73-87 chevy kit for crossover steer conversions. I wanted to see how it would clear the track bar. For once something is going to fit and work. The sway bar clears the pitman arm and track bar so its going to be a super easy install. I'm actually going to order the same style bar for the rear. I measured it out and a 42" bar with 16" arms will clear everything. I'm going to make mount tabs on the rear u bolt plates. That will give the suspension an over the top look.
Lastly I got the steering stabilizer bolted up to see how it lines up with the tie rod since its flipped with the D44 knuckles. I got a Bilstein stabilizer for a Dodge truck. All I had to do was change the bushings for the 5/8 style Bilstein sells separately. Ruff stuff makes a bolt on tie rod mount that will work perfectly for $30. So I'm going to get one next order I place with them.
Tomorrow I'm going to get the engine cross member cut up and fit the new track bar mount to it. Once I get the leaf spring issue done then I can fabricate the axle mount. The track bar should just clear the u bolt plate even with the extra 5/8" drop from the add a leaf. And hopefully it will clear the oil pan and I can leave the bar straight. This front end is taking some time to dial it in but so far I'm happy with how its coming together.
