Rockabillyrat
SlIgHtLy StUpId.
Well after a crazy summer I'm finally back to working on the truck. I just couldn't catch a break this year. We had record flooding and rain fall in the spring that set back alot of outdoor projects. Most of the farm fields near me either didn't get planted or look horrible this year, including mine. I feel bad for the local farmers. On top of that I was working two jobs. Which took away most of my free time. So any progress I made on my large to do list was slow. But by far the hardest thing about this year was my long time girlfriend and future wife lost her father. It was very sudden and has been extremely hard on her. I couldn't imagine what it feels like to loose one of your parents. But through it all I'm about 95% done remodeling and fixing up the property on our house. I bought it foreclosed and I plan to sell in a few years.
The summer hasn't been a entire wash though. Most of the outside work I did cost little to no money. So i had a chance to save up and buy some parts. The first purchase was a p400 rotating assembly I got from Twisted Steel Performance. Man this stuff looks awesome. I can't wait to see how far I can push my optimizer.
Before I can get to the engine work I need to get the chassis and cab finished. That way I can test fit everything and see what clearance I have for the up pipes and turbo. So I ordered most of the steering and suspension parts I will need from Off Road Design. I got new leaf springs and a shackle flip kit to do a 4" lift. With new bushings for everything and some of their HD shackles. I also got their cross steer kit. I'm really excited about this because it will help the truck handle better and eliminate bump steer. They require the flat top knuckles. So I tracked down a used set from a Spicer distributor that came with new Spicer ball joint.
Next it was time to get steel for frame boxing and crossmembers. DIY4x4 had a nice frame boxing kit. They don't offer a LWB kit for the k10/20 frames. So I purchased the K30 kit and I'm going to trim the middle to fit. That gave me the length I needed. I also picked up a set of their B52s. I'm running stock length front springs but the factory core support mount/leaf spring hanger on these trucks are ugly. I asked them to leave it unwelded that way I can set it up for stock springs and trim off what I dont need. CFM industries had a really cool engine crossmember that will add alot of strength to the front of the frame. And it has a tab for a track bar. With the combination of cross streer and a track bar the truck should drive like a 99-03 Ford. I'm going to build the rest of the crossmembers from 3/16 street and rectangular tubing. The factory crossmembers are weak and it will be much easier to box the frame if I change them. Not to mention it will look ALOT better. I measured them out but haven't had time to run to the steel yard to get what I need. Once the cross members are built I can box the frame and get the new suspension on.
The first thing was to cut out the factory engine crossmember and get the new CFM unit in place.
I'm trying to keep the frame from moving too much. So my plan is to do one crossmember at a time. I'm going to remove them build the new one then weld it in place. This weekend I'm going to spend time cleaning the frame and prep it for welding. I should have steel next week to start the fabrication work. Chassis work is my favorite and I'm going to have some fun with this truck.
