Nope, shouldn't be much flex - just what the suspension wants to do, which I think will be appropriate for how this truck will get used.That frame isn't gonna have any flex to it! it's gonna be stout but if you do any off-roading with rocks I would think the truck will be teeter-tottering between the front and rear opposite wheels
That’s the factory VIN stamp.Very nice work, indeed. Did you have to stamp a VIN number on top of the frame?
I’m planning on doing a generous drain hole somewhere in the lowest point of the rail. I’m also going to spray the interior of the rails with cavity wax for protection.With the boxing you're doing, how will you assure you keep the crud and moisture out so rot doesn't set in?
