n8in8or
Right on. The more I thought about it, if the hot side of the turbo setup got that close to the rails in that location, I’m probably doing it wrong.
Nah, the kind you put in your kids' second story bedroom so they can escape out the window when there's a fire would work better!A chain ladder stowed under the end of the seat would work good too. I think.![]()
Thank you for the feedback. The axle will be straddling that joint, though I don't have the exact location of the hangers yet. I did the angle in that direction because at the leading edge of the bottom of that extension is where the original frame rail kicks up (you can just barely see it in that picture if you look closely), and the height of the rail at that kick up was a perfect slip-fit for the inside dimensions of the 3x8x1/4, so I was taking advantage of that feature, but still trying to add as much weld seam length as possible, so that's why I went in that direction. Thinking back to my Statics class......are you thinking that if the axle was completely behind that splice that it would be better for the load to be largely compressing the weld seam rather than having it in tension?The fact that you angle cut the splice is wise. For what it's worth, due to the axle location (assuming it's behind your splice, if doing this again, I would have the angle this direction, though (indicated with red).
The plug welds top and bottom flanges are far more critical than those on the web.
Nice work. Do you have a shop you work with on the material or did you form those with your own brake press?
Will the window panes be welded back into position ?I was busy this weekend so I didn’t get anything done those days. Tonight I finished fitting the second rail and then added access windows to both rails so I’ll be able to add a weld bead at the interior seam in addition to the exterior ones. I’ll clean the edges of the window up with a carbide burr and smooth the radii in the corners to reduce stress risers.
View attachment 79447View attachment 79448
I keep going back and forth on that. I thought I was set on leaving it open so I could easily inspect the weld, but after seeing the opening I'm not sure I like leaving it open - even if I bolt a cover over it to keep junk out, I'm still not sure I like having the opening there. I am planning to box the entire frame because I'm concerned about the frame twisting with the dump bed in the up position and on some uneven terrain. I'm also concerned that if I only box it partially, that the place where I stop the boxing then becomes the part of the frame with the highest stress, so this has led me to the decision to box the entire frame. Now if I was to leave that window open, that feels like a huge opportunity for stress to concentrate in a twisting scenario, and I don't like how that feels in my head. So with all of that said, I think I'll be welding those windows back in place once the inside weld seam is complete.Will the window panes be welded back into position ?
I didn’t, but I’m thinking I will when I take it apart when mockup is done.Looking very good.
Did You install new center pins in the spring stacks ?
Be a good plan to do that.I didn’t, but I’m thinking I will when I take it apart when mockup is done.
