ebay will be off shore heads, I can get GEP heads as well, but yes they are costly..
Ok folks, I have finally had some time to start putting together the P400 that I have been throwing tons of money at since I had to pull it due to the inferior valve work that I had done on the new engine before I installed it back in the fall of 2014. Unfortunately, life takes different turns and we all have different priorities and this is one of those instances. I bought this highly customized truck from an NFL football player back in 1994 with only 12000 miles on it and have just shoveled $ into it since then due to my strive to perfection personality just to give you a little insight of the vehicle history for those who have not followed along over the years of my thread. This new P400 motor has only been ran 119 miles by the trip odometer on the truck since I installed it back in 2014. Any way here we go again, I will try and document and post photo’s as much as I can. So, in January of this year I took the heads and pistons to Chris @ Twisted Steel Performance to get a completely new valve job, and full heat coatings of the heads, valves, intake & exhaust runners along with head resurfacing (preparation for Cometic HG’s) and a set of his 300lb valve springs. Keep in mind these heads have had previous extensive port work and the larger 6.2 valves installed along with the EGR ports filled with aluminum. My exhaust manifolds have been match ported to these heads along with extrude honed so these heads are drivers side and passenger side specific. I also had him machine the pistons for 18:1 compression along with machining valve reliefs for the larger 6.2 valves that I have installed in the new P400 heads along with his full heat, friction & oil shed coatings as well. I have had the entire rotating assembly balanced at a local speed shop along with the block deck machined to square up for use of Cometic Head gaskets. Obviously I will be using ARP head studs. I also have installed a set of Total Seal piston rings (already installed in the photos). And I will be replacing all of the bottom end bolts using original AMG P400 fasteners which are in the photos along with AMG P400 connecting rod bearings. I will be using Clevite main bearings and the machine shop installed new Clevite cam bearings in the block. So the next move will be to assemble the bottom end with the pistons. The cylinders have also been honed in the photos. I will continue to document the build with photo’s and description the best I can.
