As I stated previously the pump only had maybe 1000 miles on it just not enough fuel so I just sent it to them and said do what you can to get me more fuel but use my .350 head and rotor instead of the .310 plunger head and rotor that you usually use. Then after I paid the invoice it stated no warranty on the head & rotor since it I supplied it. I thought I posted the flow numbers that they gave me earlier but here they are again. Let me know if you can't see them.So what did you have done to this pump this time? And what was the reason for no warranty on the work? and did they ever tell you what they did and what amount of fuel they claim it would deliver?
I don't recall me doing anything to deserve any bad IP karma! I have over $3200.00 in my last 3 injection pumps. I guess I'm not spending enough for them?Well, that could have been the issue with the 2 goofy cylinders huh?
Some bad injection pump karma at ya?
Sell the P400 and install a 2006-2007 5.9 Common Rail Cummins and Allison transmission. Anyone want it with the almost new 4L80 trans with new converter?Thanks, I see them now....
So, what's the plan now?
The P pump can be built on the kitchen table there is no shortage of parts and exotic internals too.I would probably had much better results with a Bosch P pump warranty, but I guess it would not have needed to be modified, So it looks like Fellow Traveler has made the correct decision.
Sorry, I guess I'm just hating on the 6.5s right now.
I think it is just dumping fuel in the #1 and #8 cyl, most likely not enough pressure from the IP to atomize the fuel is my thinking. The pump builder will most likely tell me that I have the injector pop pressures set to high which they are set @ 2250 PSI the pump builder recommends the pop pressures to be 1700 but I think that is just too low.
"I maybe missing something here as I suffer from "some-timers" but I transfer fuel from my aux tank exactly into the main tanks fuel fill as I drive for many years now and never ever had such an issue? So why would the small fuel return cause an issue? Lest we forget the fuel gets sloshed around the tank and surely air bubbles do form unless foam or bronze wool are incorporated into the tank like in a fuel cell.
Nope, you've got an apples and oranges thing here. Pushing fuel back to the tank from the LP vs the designed fuel return system post IP. I'm late to the thread, but he did say 'from the LP.'
If you have a dedicated regulator that has a return/bypass line off of it you don't have to worry about it siphoning off when it sits overnight. You can also have it feed into the filler neck with no issues. I have a system setup like that on my stepside. Can sit for months and have no issues.
The other nice thing about a full flow bypass is the pump can run flat our and the engine just pulls what it needs.
2250 psi is not really that high. I will be building a set here soon at 3200 psi or higher. The only downside is no hot starts,if the head and rotor are worn.
