dbrannon79
I'm getting there!
yes, all new OPS. that was one of the thing I tested to make sure it was working when I discovered the lift wasn't working this weekend. had my son cycle the key while I was testing for power at the pump. then found my goof up with the ground disconnected !! now that the lift is working, pressure isn't looking too good.Did you replace the OPS when you did the relay mod?
