ak diesel driver
6.5 driver
It's in here somewhere LoL
I've been reading a lot on the different pumps on the larger trucks and it seems there was two different pumps made, those that had convex end caps and concave caps. both of the pumps had concave caps on the housing. from what I have read, the convex ones had more flow and are now almost impossible to find. all the auto parts have been using the convex style for all light and heavy duty vehicles. not sure if this is the case but I did make sure the opening in the port on mine had the larger hole where the pressure line connects on the pump I have now. I found this info over on a jeep forum where they were using these pumps when adding a steering ram along with hydro boost.Thanks for the comment about my truck, still a work in progress. Don't have much help for you in the power steering issues my first thought would be power steering pump but you've already changed that
your absolutely right. I wanted to take care of the fuel issue first. this was just something that came to mind while reading about @ak diesel driver's new truck. new hoses are on the list and then I'm going out to talk to a couple of the local shops in the area and see if they can test my pump at least. it's something I get the feeling it isn't right but then again this is the biggest truck I've owned plus my first diesel on top of that. it might just be this way and I'm not used to it. it stops and steers so I haven't put much effort into this part other than fixing all the leaks lol.I Get not wanting to buy a tool for a ‘one time use’. But how much money and time did you spend on all those parts and still something isn’t right. Buy the tool and diagnose properly, or fir the parts cannon and it and still not right is often the issue.
It could be, a hose is coming apart inside and restricting flow. That hose coming apart means low performance and contamination that puts tiny rubber particles at the seals and causing leaks. I am not saying replace your hoses- i am saying proper diagnostics is the lower cost answer 95% of the time. If you don’t have the tools and or skills, find someone with a stellar reputation (which means they will charge more then others) and pay them to do it, so it is right the first time.
it has some issues I have tried to deal with but no luck yet with. my steering is stiffer than normal or stiffer than I'd like plus the brake pedal is harder than I think it should be. I get so used to the brake pedal in my truck that when I get in my wife's little car and step on the brake, everyone tries to go through the windshield!!
While trying to mess with that issue and fixing all the steering slop back when I bought the truck, I've gone through two pumps, two boosters and three gear boxes, mainly due to leakage, but none have had any effect on improving or giving an easier to steer condition. I think it's pump or fluid flow related, but I'm too damn cheap to buy a pressure tester for a one time use!!
No, not normal.something that caught my attention yesterday that I'm not sure if it's normal but yesterday when taking my wife to to the dr's office I pulled in the parking lot and shut the truck off while my foot was still on the brake pedal. after the engine was off the pedal fell to the floor!I stepped on it again with it off and it was hard and stiff like I would expect without the engine running. is this normal for a hydro boost to just fall to the floor when shutting off the engine?
