I will be offering a brand new lift pump from Walbro. Its so new to market that they do not have lititure for it yet, but it is basicaly the same pump as this discription, Except new pump will have 1/4" ports, and higher psi/gph rating.
Price will be $125 on the next 4 sold.
FRC-8 Reciprocating Fuel Pump (For Reference Only)
Performance
Voltage: 12 Volt (9.0 min – 16.0 vdc max)
Minimum Flow Rate: 106 liters per hour (28 gph)
Deadhead Pressure: 62 to 83 kPa (9.0 to 12.0 psi)
Maximum Current Draw: 2.3 amps
Life: >8,000 hours
Dry Lift: 48 inches
Compatible Fuels: No-lead regular gasoline, premium gasoline, gasoline-alcohol blends, diesel and biodiesel fuels (20% and 100%), and E85
Corrosion Resistance: 96 hour salt spray test (ASTM B-117)
Operating Temperature Range: -40ºF to 155ºF (-40ºC to 68.3ºC)
Electrical
Reverse Voltage Protected
Transient Voltage Protection
Ground: Circuit Board is Internally Grounded to Pump Body
Electrical Connector: Packard Electric (Accepts mating connector 12015782)
Fuse: 5 amp recommended
Mechanical
Inlet & Outlet Size: 1/8-27 NPSF
Inlet Filter Screen: 70 micron
Magnetic Trap Standard
Outlet Check Valve: Yes
Available Options:
Adjustable Pressure Regulator 135-631
420 micron Filter Screen
The FRC series fuel pump is designed to supply fuel for internal combustion engine applications only. It is not intended or designed for continuous operation applications such as heater or stove systems.
Performance
Life: >8,000 hours
Dry Lift: 48 inches
Electrical
Mechanical
Available Options:
