ak diesel driver
6.5 driver
What about installing a bleed screw at the high point?
Loops or any "P" traps might need to be bled too.
Yeah sorry forgot about the connector. I think its the same as some import horns also like on a Volvo IIRC. Might even call GM and see if they have the pigtail for it.
Yes I would.Plus I've already insulated it with the Tunnel Shield and if I was to put a hole in that I think Leroy would cry![]()
Thanks. I'm just babystepping towards making it all that I want it to be.It appears to make quite a difference, congrats and a job well done.
Did you unhook the cooler and tilt it near vertical to bleed the last of the air out? Might have to fill it while loose at an angle to get all the air out and do a surge tank a bit higher on the firewall like the radiator for a little expansion room. But it looks like you must either have a bleed screw or fill while loose and move IC around and keep lines up to let air escape.
Is Water Wetter the same as water soluble oil?
There are several companies that make this tool, or make one yourself. Makes life SSSOOO easy when dealing with any coolant system that doesn't like air pockets. Also keeps you from filling a system that has a tiny leak.
Guy in video says 25 psi- wrong 25 hg, but a good video otherwise.
Btw did you add any water wetter/ water soluble cutting oil to help it work better?
How much WSO would our cooling system need? I have it in 5 gal pailsYes,
It's a high grade one. All is does is modify the surface tension of the water so there is a tiny bit more contact between the liquid and the metal. That's why machinists use it on the equipment is to help the water do it's job.
