bowtiebutler956
Active Member
Very Nice Nate.
You do first class work, so I'm sure it will turn out very well, and I look forward to following.
Matt
Matt
I found the pump. I found it for a 2003 CTS. It's called the Auxiliary Water Pump. It's only $70 on Amazon (Cardone brand). I wish I had known about this sooner, dang. It even has a built in mounting bracket. I'll probably upgrade to that in the spring and just use the existing Rule pump for the rest of this year since I already have it. Thanks for the heads up, I'm sure that's a much more reliable pump.x2. I'd get the Cadillac pump. I think around 2005 forget the model, have to google "Cadillac electric water pump" or similar.
Shroud looks good, maybe make a mount for the pump on it too?
Funny you say that, that's exactly what I had planned. I want the intercooler to focus on cooling the intake air and not have to struggle with engine compartment heat too.I wonder if you wraped it in same stuff as firewall if it would help keep heat out? Sure would look cool anyway. Those aluminium parts start to look bad real fast. Im not the type that is going to go polish my IC once a month![]()
