schiker
Looks cool. Another thing to drool over and dream about.
Thanks Leroy. I used to work as a welder making expensive outdoor furniture. I'm not as good as I used to be but most of the time I can do well enough for myself.Nice welds. I have the same machine, but don't have the touch like you.
Thanks, I can finally be done with this idea rattling around in my head!Looks cool. Another thing to drool over and dream about.
I had an extra hole in my stock manifold too. Don't know if I'll ever use it but it's easy to put in now so might as well.Good idea on the extra hole, I also did that on the stock manifold. It still has a plug in it.![]()
Thanks! I would love to have it coated in White Lightning to keep heat in and keep other things cooler but I don't have the budget for that right now. I also don't want to wrap it because I'm afraid of rust since we salt here in the winter. I did buy heat wrap for all the hoses and wires nearby to protect them and I also think I'm going to make heat shields for the fuel lines and battery and stuff.Very cool. Speaking of temps, you might see an increase, underhood.
One thing to remember on equal length and all that; throw it out the window on applications like this. Also since the exhaust is supplying Drive Pressure, equal length and super big tubes need not apply. Your best bet is to keep from losing the heat needed to drive that turbine. Wrap that bad boy up!
Very crafty piece, LIKE!.
Hmmmm I hadn't thought about that. It's pretty stout as a structure with all that tube, but a brace of some kind might not be bad. Maybe from the flange to the intake or something.Looks great. Would it be beneficial to put a brace from the back stand off to the crossover flange or collector/splitter tube? Or would thermal expansion movement pull it away or other? Anything in the way there like heater hoses etc?
I was thinking about this some more....you are more concerned about the pipes that are hanging off the back for the crossover here right? I think you might have a point and I may add a brace to them. I'm going to look into that. Thanks for mentioning it.Looks great. Would it be beneficial to put a brace from the back stand off to the crossover flange or collector/splitter tube? Or would thermal expansion movement pull it away or other? Anything in the way there like heater hoses etc?
The more I'm doing this stuff, the more I want a TIG and a plasma cutter. A vertical bandsaw would be nice too.It's not always easy to predict where stresses wind up turning into cracks when fabbing turbo headers. After they've happened, it seems easier to sort out/theorize why it cracked where it did,...but challenging when building something new. It's not uncommon to see manufactured turbo headers get better over time as they analyze failures & improve how they build it.
It's cool to see your process & how it works out. I've wanted a TIG machine for several years now & this winter might be the time to get a bunch of practice in.
Shoot, sorry Leroy, I didn't realize you had exhaust wrap on your site. Shoulda known.Get some of this http://leroydiesel.com/products/exhaust-wrap/ and paint over it after installed with your favorite high temp paint. It will help seal and "glue" the wrap in place.
I like the brace.
