ak diesel driver
6.5 driver
Might put one of those braided flex pipes on in the crossover
I don't know just typing first thoughts.
I agree the tubes are different temps. Might be the (2) crossover tubes coming from drivers side aren't exactly balanced and one gets a little more flow. Tubes coming from drivers side would also cool faster than number 8 tube I think.
If it happens again.....
Might consider beefing up the standoff and stabilizing the drivers side tubes to it instead of the tube from number 8 or maybe not so close to the cylinder. The way the crack developed in the face of the curve where the gas hits to turn sorta gives me pause to wonder it is seeing the extremist hot spot.
Maybe not. The gases in the drivers tube would have a delay of temp change heating up and be a bit cooler from distance but might delay cooling too. The face of the curve would also see the fastest cooling effect of cooler exhaust coming out of number 8 say on a compression braking event????
#8 is always the classic hot spot anyways. Plus the whole bad cast issue in the 506 blocks where the #8 cylinder was goofed in casting. Where it really showed up was the centermounted turbos with the up pipe trapping extra heat to the head. Combined with the lesser flow from unbalanced water pumps- gm warrantied a ton in hummers and vans.
When your pushing the egts up there the extra 5% heat in the #8 could make the difference.
The patch should do it I think.
That's true, it would have been more of a tick not a rumble. I guess my ears were just out of calibration.A hairline crack willjust give a tick. And between the wrap and the natural sound of a 6.5, it would be impossible to hear.
Something that hits me now I should have said earlier. peen the welds, heating in an oven up to 450, hold for an hour. Lower to 350 for an hour, 250 an hour, then shut off and let cool in the oven. Really there is a ton of temperature levels and range of drop. The exact temps are better known by a real exhaust guy, but any heat tempering like that will help. So when the wifey starts wanting that new stove in the kitchen, rember you get the old one as another tool. Maybe a little ceramic coating here and there...
Best thing in the world if you get rich and famous is cryogenic treatment. That makes a massive differece in strenght, but if it is just concentrated heat related, that wont help much. It's more for vibration and overall strenght.
I didn't explain it very well in my earlier post (I was rushing to get it all posted while I was grilling), but I did untie the tubes and now the crossover tubes are just supported by the stanchion. But yeah....they are still quite close and that is still going to be a hot spot.
Not being mean here.. you will be chasing a crack every time you turn around, just in the nature of the material & way it was welded, kinda thin & miged, both are going against itself...
It looks like the tubes are welding together from underneath view. So if you separated the No. 8 tube from driver side tubes I think that might help. Being the only area that is not wrapped is also allowing faster cooling. I have seen a dulled air chisel or air file used to peen relieve some stress of through hardening heat treated piece of flat tool steel that bowed in heat treating. For peening would an air needler work on a weld?.
