Jorge6.5
I would be very happy with that as should you!
I still think you should make a hx35/hx40 hybrid. Should spool like a 35 and put out even more volume of air.
My HX40w CKO lites up right away w/Heath's Maxi Torque tune, bellows a good amount of black smoke when I nail it (way more than w/GM8) which soons dissipates and my Burb hauls a__ and mean really hauls. I'll be getting the HX40 specific tune Bill recently did for someone for their 6.5td w/4L80. My driving style has changed by not having the need for lots of pedal input as before.
I suspect the later smoke on your 6.5 is bypass under boost!
The easier spooling w/auto is because of tq multiplication of converter the more "X" built in the quicker the spool however a manual with a deep 1st gear should spool fast too with more pedal input IMHO.
Finally someone else who knows that a torque converter multiplies torque. You wouldn't believe the amount of explaining and arguing I have done with people over that!
Excellent!Why argue. Point them here and walk away if they don't get it:
[Video]
That's about as simple as it gets. First year mechanics stuff.....
Also, saving for a Duramax, so money for the 6.5 is going on the back burner.
What Carter pump are you using?
Just wait until you read all of the mods possible with the DMax.
Really just looking to do basic stuff, intake, exhaust, egr delete, edge tune.
Half the reason I want a Duramax is to take the 6.5 off the road for a bit to play the go-fast parts gameHeheheheh . . . That is where it starts. But rarely where it ends!
Shortly after going down the DMax road, one day you will wake up (probably right after pricing a set of rebuilt injectors), go running back to the 6.5, and beg for forgiveness!!!
