Jorge6.5
Still running the 35? What do you have max boost set to?
An HX35 should build boost very quickly, unless your your not putting down enough fuel. Any slow boost issues will only be amplified by going to an HX40.Initial impression is I don't like it. Less smoke on a take off, builds boost slower, have to really push it to get it past 15. Stock MAP would give a little puff on a down shift and make 15 all day. We will see how it plays out.
Matt
Actually. You have a hx35 and a 40. You should look into making an hx35/40 hybrid turbo.
Changing the MAP resistor doesn't change your boost. it changes how much boost your ECM 'sees', by altering the input scale.
With stock setups, that changes how the ECM will refuel things if the combined boost seems too high.
Update on the 3-bar, found a boost leak (surprise, surprise) on the coupler from turbo to intake, truck now makes 15-18psi relatively easily. Still feels a little more sluggish on a downshift than it did before. Oh well, at least it's not limp mode. Too dark to check for smoke, will do that in the morning. Have a gut feeling it just doesn't fuel as hard.
TVM- I've seen those wheels, $40 for OE sounds sketchy. I know it's cheap, but I think Im gonna keep the 35 for now, and really grind away at getting the NV4500 in. After that, I will turn my attention to fuel. I foresee a crossroads, I can either bite the bullet and do a DB2 on this engine or get a tune for less money. Decisions, decisions...
Back to the Tranny . . .
IIRC the NV4500 is good for 460'/lb (probably more, but that is the rating). Seeing as the goal is to squeeze more power out of the motor which will probably get it in the territory of the NV4500's torque rating, might think about getting cryo parts or just bite-the-bullet and get a new unit with cryo parts. Happen to know that Midwest Transmissions does cryo as well as the 5'th gear fix in a new unit.
Yep. Damn boost leaks. The make a huge difference. What cross over pipe do you have? Having a good non leaking one really helps
Idk about the rating on the NV4500. I am well within that realm of 460ft lbs when I'm injecting and she has been holding fine. Not missing a bit except getting crapped on with another bad tranny. Damn deals, too good to be true haha
