Remove the four screws holding both halves together and it will fall out.
Best idea yet. let us know if it works.Ok I am hoping that I won't have to ever take them out again but a little rubber o-ring kit I have in the workshop should do the trick
Are the Kodiak handles even available anymore.. ???
Wow, they look expensive. here's the cheapest I found : http://www.ebay.com/itm/DORMAN-760-...es&hash=item485477be40&vxp=mtr#ht_1752wt_1399
rockauto sells something similiar for 25.00
Type in these part #'s on http://www.rockauto.com/catalog/raframecatalog.php and let me know what you think.
GM1311177
GM1310177
nice first post!
Yes please do i have a 98crew and would like to get ride of the stock handlesSomething I've wanting to do for awhile now. These handles fit a 88-2000 Kodiak or whatever years that they had the same cab as our P/U's.
I bought everything new, but a junk yard if you can find one will be cheaper. I am actually looking for the rear handles and linkage if someone knows where a set is let me know.
Linkage for the Kodiak is alittle shorter. Old one could be cut and rebent.
You need a few parts like the lock paw that go's on the lock cylinder and the linkage from the cylinder to the lock latch and a few clips.
New handle is a bolt on deal except for the linkages.
I have all the part #s if anyone is interested I can post them. I also buy wholesale from GM so I can round up the parts also if needed.
