FellowTraveler
After many months of shake down runs on my Cummins conversion and tweaking things I’ll be moving to a 400 + HP build using a brand new Genuine Holset hx40 67mm turbocharger.
I hate haze and smoke bellowing so I’m still deciding on exactly what p7100 mods injectors etc. for this build.
Here are the specs:
.82 T3 flanged exhaust housing non-gated (which falls between an 11 cm2 & a 12 cm2 turbine size) w/50mm BOV set around 20 to 25 PSI
3 inch band outlet into 4” down-pipe
67mm by 89 by 95 mm 7 blade billet compressor wheel
67mm by 76mm 10 blade turbine
Good for 950hp + at 35 to 40psi
750 to 850 20 to 30psi
However; HP #’s cited above are for gas applications so diesel HP #’s would be about +- half of that.
Here are the specs:
