FellowTraveler
Thank you very much, I keep driving on staying ahead of the reeper............I hope and pray that all is well with You.
When I had seen the prices of high capacity 47/48 series big case transmissions it was "STICKER SHOCK & ALMOST A SEIZURE TOO" so I decided all that extra $$$$ the builders get would do better in my pocket, the only thing missing in my approach is that little sticker the builder sends with the trans you just paid $9k or better for.If I would ever get a Dodge with one of these transmissions, I guess I now know where to send it to get all of the uprated components done.![]()
Yep, built to take the punishment that's what this build is about.That's one beefy looking band compared to the OEM one!
As an additional parking brake.I like the idea or extra support.
On the drive line disk brake- as parking brake or just added stopping power?
In my AO three Ram Cummins with the 48RE had the 4x4 O/D extension snap there has been for a few years now a mod using the GM Square body trans mount from x-member to the t-case.@LowRam added a mount to the transfer case in the H1 conversion. They kept breaking driveline parts before that was added. I can’t remember the details now.
i just talked to him the other day - the original Cummins setup from firewall forward is going in another Hummer and they’re going to be building a new 2000hp Cummins for it
The one I use most these days is "whiskey tango foxtrot."19 years in the Army, the last 16 of that as an Officer. Understood that transmission Lima Charlie.
Before or after you discover that it's a Charlie Foxtrot?The one I use most these days is "whiskey tango foxtrot."
