Thats good news, if they were grey I would have to start concidering if I wanted to carry them any longer. Thanks.
Youve gone through two new Stanadynes. Impressive. Are you using a thermal pad between the PMD and heatsink, or some thermal grease?
Is your alternator output a little high? Ever more than 14.4V?
14.79V may be a little high, does it keep going up with RPM? You can run a scanner while driving it, or just have someone rev and hold the engine at 2000rpm while you test it. I'll have my Wife hold the Accelerator Pedal at 2000 and I'll check the Voltage at the Alternator as before!
Test ran the truck today, ran fine! I guess I had another bad PMD! Picked up the Lawn Trailer from my Sister-in-laws house and brought it home for Mowing Season and the truck ran fine!
Unfortunately it is Yes!Im slow, so are you saying the one I sent is bad? (please say no)![]()
OK. Well send it back I'll get another one out to you. Sorry for the problem.
Not your fault it failed but I am trying to check everything possible as I don't want this to happen in another month! Also,I am curious in the price difference of the D Tech and a 6 ft. Cable for it. Can I use my Stanadyne #9 resistor with it or will I have to buy another for the D Tech?
Grey Stanadyne cables cost me more because of the gold plating and the connector cost more.
You can sand off the polarity tabs on the resistor, BUT then you have to be very carfull not to get it in there wrong as there will be no way to line it up and you could install upside down. Best to just buy another.
But It seems to me like the Stanadyne IS the problem and I am willing to spend more Money on a Cable/D-Tech/#9 Resistor Combo if it will stop this from happening again! That way I will have The D-Tech Package and as emergency back-up, the Stanadyne Package.
OK, I thought you were asking why the Grey cable cost more.
The Dtech or FS PMD kit cost the same, but is less than the Stanadye kit because the cable cost less. I actually have a very good offer on the FS PMD right now $205 for FS PMD and #9 resistor. Heat sink and cable is $89. so, $294 for a kit. If you don't need/want the heat sink take off another $40
http://www.thetruckstop.us/forum/showthread.php?t=21485
I'll keep my Grey Stanadyne 6ft. Cable from you but return the Grey Stanadyne under Warranty and buy the D-Tech/Cable and #9 Resistor without the Heatsink, how much is the difference?
that wont fit where i got mine on both trucks,i wanted to use it as a spare with bolted on PMD.
