bison
i got a couple APP's on the shelf,might be to far for ye.
My friend is putting a cummins engine in his 98 gasser ram. He was told he cant put a 12 valve in due to non obd-2. Would this be the same with an obd-2 gm? Like going from ds-4 to db-2? Just an interesting question. My friend has to put a 24v in if he is going to swap, which fortunately he found.
And this is different to a DS4 in what way? BTW, I do not add additional lubrication to my fuel and my DB2 has not died an early death. I don't think a DS4 does very well without a functioning lift pump. There are more DS4 "fixes" for sale and threads on how to keep one working on virtually every 6.5 website out there than I can count. How many places sell "fixes" for DB2s? How many threads on all of the failures of DB2s? Yes, like any mechanical component, they will eventually wear out. I wouldn't consider normal wear a failure.
Thanks but I think Alberta is a far stretch from my neck of the woods! I would drive within a 150 mile radius of Cincinnati,Oh. for a new one if it did not have to be purchased with the Pedal Assembly as GM requires! The one I checked today had an ohm reading of over 7K on on of the three sets of pins!
that doesnt make any sense. they had 12 valve cummins trucks in production in 98.
Magnum,........Maybe this helps, if you didn't already purchase a pedal assembly.
Contact member, Extremesounds13
http://www.thetruckstop.us/forum/showpost.php?p=246141&postcount=2
:smile5:
New Gray Stanadyne PMD and Extension Cable From Leroy on the Vendor page! Truck restarted after sitting and drove back home! 7 psi fuel pressure gauge under the hood before the IP, can hear LP running before starting truck and opening Bleeder on Filter gives a strong stream of fuel. I am going to let it run in the driveway while working in the yard and if it quits and won't start back, crack an Injector line to see if it is getting fuel!quits with no codes. This is different than problem before right, where it ran but no throttle response? Exactly, engine ran but no throttle response before but didn't quit!
When you put PMD to the bumper was it a new PMD and where did you get the extenstion?
When it died did you lose anything else, like the radio and gauges? The SES light should have been on and check gauges and such. If not you could have an ignition switch issue.
The thing with the IGN switch is it could burn contacts the provide power to the PCM or PMD and ESO but still provide power to the starter. And it would be intermittent. And it is common.
The reason the SES or check gauges light is important when it stalls is that means the PCM and instruments are still powered, and it should be with the IGN in the run/on position when it stalls. If not then you know its an ignition switch problem. Also every single time you switch the IGN to ON/Run you should get WTS/GP and an SES light on until you crank. If not PCM is not getting power.
