turbovanman
I has boost, :O)
A point that everyone forgot is :when the engine is shut off, the cooling system pressure is greater than the oil pressure. The coolant will go into the oil.
If the engine was run with water or anti-freeze in the oil the bearings are history.
A engine that has sat for 10 years should be opened up to check the cylinders for rust. Just the condensation from temp change will rust them. I'd offer less than $300 for it.
That is true but he has oil in the coolant, that was his first symptom, :sad:
