Acesneights1
and I changed the oil right before I took the heads off, actually thats how I found the original proble was when I was changing oil and checking coolant and I discovered oil in radiator
Oooh. Bad. Should change the oil right after. I GUARANTEE Water got into the oil during Head R and R. Now onto the oil in the rad. You are saying after replacing both HG's and flushing the cooling system and installing a new rad that you now have ALOT of oil in the coolant AGAIN. I doubt not milling the heads is your issue if the machine shop checked them. Milling is generally done if there is warpage and if they checked and magnafluxed them I'm gonna assume the checked the plane on them. I would do what I said at this point pressurizine it and start with the oil coooler lines removed. If you get no evidence of pressure out of the oil cooling lines while the rad is pressurized then unfortunaley you need to move onto the engine. Also while your oil cooler lines are disconnected and you are pressurized check the lines as well for pressure. It may be worth while to have the engine heater plugged in and motor warm while doing this . It's gotta be going somewhere. Somewhere there is a breach between Oil and coolant. By pressurizing the coolant hopefully you will push back out whereever this breach is. Remember that while you are pressurizing the cooling system, the engine Oil pressure is zero so it should pusyh back whereever the breach is.
