Your budget & application counts. Everything Doug said above is on point.
If you pay for oil testing you will learn how often you need to change it based on your use. Different environments, condition of the engine, and how you run it makes a big difference.
I have worked in oil& fuel industry side where a lot of testing was done, made friends with some petroleum engineers. One of whom when I was asking about some of the more wazoo oils- started telling me about tribodyne. He said it would be many years before the nearest competitors get close to them including the place he was working for (can’t say who but their name is always in the random top 5 lists).
The wazoo oils if tested To prove when they are done is still more expensive than many others but the idea isn’t pinched pennies- it’s getting a longer life and more efficiency from the engine while in use.
Wix (aka Napa gold) filter is still the best one made as a normal filter.
A Frantz bypass filter is my recommendation for most folks to take it to the next level.
My plan for my engine build that is about 10 years past due now is adding a drain & refill hose from the pan so I can hook up a 120v powered centrifuge for removing the soot while it’s parked. Unfortunately almost none of the centrifuges that are used in bypass mode clean any better than the frantz because it takes 100-110psi oil pressure to spin it up to speed for the 1/10 micron a centrifuge can clean to.
Do You have the FRANTZ part numbers so We can order those filters ?
Can they be ordered direct from FRANTZ ?
If there is a web page where we know we will be getting the real McCoy, could You list that too ?
We dont want some cheap @SS’D chinese knock out, ooops, knock off. 😹
Slightly off topic, but given that we're on the topic of oil....
1. Best oil brand? (Valvoline, Rotella, etc) and if Rotella, T4 vs T5 vs T6 vs T7
2. What do you all think about Diesel Oil Treatments? HotShots, ArchOil, etc
(https://www.hotshotsecret.com/signature-series-oil-pack/
https://www.archoil.com/products/ar...fNcjUHmPqwe7XEVh9bRIQAOKU4z_qvXyBpwGbmnpRA-fT )
Changing my oil soon, so its been on ny head lately
Also, should I change the fuel filter along with every oil change aswell? Currently using the WiX spin on filter
I most often changed my fuel filter with the oil.
I ran only full synthetic engine oil.
I also ran a bypass filter and changed the oil between 10 & 20,000 miles.
The filters listed previously are good. I also liked Amsoil, Baldwin & Mobile1 filters.
I used the FS2500 and Amsoil bypass filters. I preferred the FS2500.
I T'd into the return line from the engine oil cooler to supply the bypass filter and returned to a nipple in the oil fill neck.
You want the nipple in the oil fill neck pointing slightly down so it doesn't splash out if you take the fill cap off with the engine running
Has there been any testing of the bypass filters?
Yup. Even doing the toilet paper as the filter they smoked all the competition.
Frantz is who all the other bypass filters have been trying to copy for decades.
The original design was literally use a roll of toilet paper as the filter media but people freaked out so they made a regular filter. Both TP and their filter cleans better than new oil comes out of the bottle.
I have one of the toilet paper ones. If I can ever get my engine built I'll be putting that on it. Just need to make sure the TP is the hard and dense roll similar to what you find in the porta potties you hate to wipe with. LOL
If it's similar to the porta potty paper, can you still get the same results with 40 grit sand paper?
Use engine degreaser is fine, but it isn’t friendly to wiring harness. You’re better off using single fire rather than the three round burst mode here. With the air intake system both pre and post turbo having been a diy project- use caution on cleaner and especially water.
Spraying off is where things get questioned-
Spray more appropriate adjective would be RINSE off with a garden hose turned one third of the way up and paying attention to not soaking things like the air filter, cdr grommet, etc… that is fine. Using a 3,000 psi pressure washer and just blast everything all over the place- not as much. The fittings of hoses, ok but not the rubber hose section. The aluminum & steel of the engine, trans & transfer case- no problem. The whole rest of the underbody is ok- just not the wire harness, rubber part of fuel hoses or brake hoses.
It isn’t that a pressure washer can’t be used- but you better understand what can take it and what can’t- using caution and understanding you can do serious damage.
End result of using T6 Rotella Oil, she's LEAKING like no tomorrow lol.
I have collected oil samples in the container and will be sending it out, it'll be interesting to see what the results are, hopefully its good news
Was also thinking about dropping the pan to see how the cranks look, but, im not sure
Went right underneath the motor and took photos, im currently away from the vehicle but ill take more when im back, oil levels seemed well when I checked, and, the photos with the guages shows what it was when I was doing 65 MPH
I couldn't find any signs of leaks from an oil cooler line. So perhaps it is a front seal, but what do you all say?
(First photos of guages when doing 65, second below it when at rest at a stop light)
