MrMarty51
Years of doing wheel bearings a person knows when it is good.
Finger tight on the nut then backed off slightly, after the bearing has been fully tightened then backed off to completely loose.
Hold the left side of the brake drum with the lalm of the left hand and hold the right side the same with the right hand, alternately grip and release the backing plate with the fingers while feeling and watching for movement of the drum/hub. If no movement is felt then back off the nut about a 1/4 turn at a time until You can feel or see a very slight movement between the hub and the axle. Then slowly tighten the nut down until that movement is just gone then stop. Install the rest of the retainer devices, washer and jam nut or possibly just the jam nut and tighten down the jam nut and bend the tab washer over a flat or a corner of the jam nut.
Slightly backed off from finger tight should be good, or, the adjuster nut just bumped up to the bearing.
Keep trying and feeling that adjuster nut until You are satisfied that it is not too loose or too tight.
