bison
Unfortunately everyone has been confused and you removed the pertinent info from the first posts. I have been trying to point out he does not have any starting issues, its a bad idle issue after startup, but have been contradicted on symantics of poor performance after startup and warm up idle issue.
Quote from his original post
First thing in the morning. glow,start [very quik], instant fireup on all 8. 1 sec later engine falls back to very low idle,starts bucking and smoking bad. And has NO pedal control left [dead] This goes on for 1 to 5 min depending on ambient temp. the colder the longer it takes.then engine comes suddenly back to life ,smooth running and pedal control is back. then truck starts and runs fine all day.
Another question....
Is this the same vehicle you wired up the high idle with 12V instead of ground? And you have the remote start on?[/QUOtE
Nope, the 95 did not have high idle or remote start(it was bone stock),high idle and remote start is in the 98.now before you point fingers.The high idle has been corrected and it works fine now. Aplying 12 v to 12 volt apparently did not cause harm to the PCM
second:the symtom described is identical to the symtom experienced in the 95 wich donated the IP and the engine.
third: i did not delete the first batch of posts, Turbine Doc did cause he felt it was confusing,and transported the rest to this tread
