bison
yes, you read this right.I have considdered swapping pumps,but if the issue is the pump itself[wich i try to find out] then a warranty pump would be in order, as this pump is only 3 or 4 yrs old.If I read this right, the only thing that the 2 installations have in common (electronically) is the IP. Is the IP from the 98 in good working order? If so, you may want to consider a swap.
