Acesneights1
Is the 88 column non tilt?
No it's tilt. It looks the same to me. I hate these columns. What a PIA to work on. The newer ones are definitely better.
Lookin at the motor tonight, this thing may not be as sick as I thought. I think the problem is the turbo is not pulling the vapors in. Could be part of my low boost problem or because the POS cone looking air filter is not causing enough restriction to pull it in. I pulled the CDR pipe out of the elbow of the aircleaner and it had no pull at all unless I brought the RPMs up. I am pretty sure my boost problem is the crossover is leaking like a sieve. Frigging exhaust shop charging me 200$ to make a new one. Talk about no vasoline. New crossover should help the boost so I'll see if that works. The truck is smoking out the breathers(very little and I am certain it's oil, not coolant) but if I bring the rpms up even a little it's gone. Seems it just isn't pulling enough at idle.
I was meaning HP and TQ
Could not find Heath's cold air setup.
Hastings are GOOD!
