88 93 diesels only had a TCM.
Automatic only. Manual tranny has none.
The drac box is renamed speed sensor buffer[white plastic box ] The buffer is attached with velcro to the plastic wiring conduit on the back side of the dash to the left of the glove box.
Well, I went out to the 92 (dads C3500HD in sig, 6.5L 5spd 2wd) and we got low coolant, glow plugs, battery, and check guages. no check engine, or service engine light. so either we are in the same boat, or we dont have such lamps!
Cool, thanks. That helps alot then. The aldl connector may only be for the abs.
grounds ground grounds...There was a small cut balck wire with like a grey stripe that looked like it should go the intake so without a wiring diagram, I took a chance and grounded it. Speedo now works as well as the fuel gauge. I was so happy I could not wait to take it for a test drive...that is until the clutch master (brand new POS made by third world sub species) started blowing fluid out the bottom(not the line from what I see)..:suicide:
yes, all plastic. Is there a better one ?
