Will L.
the governor in the pump...
Tell Conestoga what you want the truck to do and they will build the pump for you. Also Unique Diesel, who is a site vendor, does very good work.Right now my truck just goes limp at 3000. Pulls like hell up to that point though.Sounds like I need to contact Conastogaand order up a Bull Moose.
ARB carrier for the 14 bolt ff can be used with all gear ratios.Hows that new gearing working? I have a full float 14 bolt with 3.73's in it. It has an ARB locker. not sure I could put in a 3.42. At least without replacing the locker.
No new gearing yet. I did get a used set of GM gears, but that's it so far. I'll slowly collect parts and then eventually switch. I am still excited to do the swap though. When I pay attention to it, it spends so little time in first gear that it should make a nice change in the truck both just driving around and on the highway.Hows that new gearing working? I have a full float 14 bolt with 3.73's in it. It has an ARB locker. not sure I could put in a 3.42. At least without replacing the locker.
Front clam shell diff is PITA to set up, then there is the industry wide manufacturing defects of the newer styled outer seals 'cocked in their housings' and leaking like crazy so it becomes an effort to get good newer styled seals that are manufactured right.The awesome thing about the 14 bolts is how easy they are to set up. Pretty sure whatever you got in the front won't be nearly so easy.
Good to know. My plan is to get a unit out of the junkyard with the right gears and swap the whole unit. I was thinking I would open it up and inspect and reseal, but perhaps if I get one that isn't leaking I'll just leave it alone and put it in as-is.Front clam shell diff is PITA to set up, then there is the industry wide manufacturing defects of the newer styled outer seals 'cocked in their housings' and leaking like crazy so it becomes an effort to get good newer styled seals that are manufactured right.
There is some info on web to use GM's seal however it appears GM has switched to the defective units too so inspect them carefully and do the job right the first time.
Outer seal replacement requires a heavy puller for drivers side to remove the drive flange, the pass side requires the removal of the steel extension housing then remove the circle spring clip to remove the shaft "in all cases new circle spring axle retaining clips are required."Good to know. My plan is to get a unit out of the junkyard with the right gears and swap the whole unit. I was thinking I would open it up and inspect and reseal, but perhaps if I get one that isn't leaking I'll just leave it alone and put it in as-is.
When I ran 3.42 gear sets near stock the Burb got great mpg's as I modified for performance the peak torque output climbed up the rpm scale to the point I went back 4.10's now that I'm going w/Cummins conversion I'll do 3.42's again....When you finally get those 3.42's installed, Nate, do some hwy cruising mpg runs (like at a steady 75mph on the Interstate for 30-40 miles) and see how much your mileage has improved over the 3.73's. With the 3:42's you should be sitting right atop the 6.5's torque peak, and with your build up, power should be effortlessly on-tap
Will do.When you finally get those 3.42's installed, Nate, do some hwy cruising mpg runs (like at a steady 75mph on the Interstate for 30-40 miles) and see how much your mileage has improved over the 3.73's. With the 3:42's you should be sitting right atop the 6.5's torque peak, and with your build up, power should be effortlessly on-tap
