n8in8or
Haha! My family is looking at me crazy from me cheering "flat 14!" out loud. Awesome man.
Whats the deal with the smoke limiter and the runs? Were you cutting back on the fuel for those runs? No, right?
http://www.ajdesigner.com/fl_horsepower_elapsed_time/horsepower_elapsed_time.php
14.00et &5900lbs says 425 hp. We know its really a lower end torque number because the engine will never hit the 5252 rpm torque/hp match up, but makes me wonder about your flywheel torque numbers...
Also how fast is full loaded acceleration of engine rpm from 1,000 to 3,000 rpm. Hmm.
Very nice.
That's hilarious! Though I feel like your family should be used to outbursts from you!?
Correct, I had the puff limiter wide open, however there is a chance it could still limit the fuel if I have it screwed in too far and it's limiting overall travel of the pump. That's something I want to play with on the dyno.
You lost me regarding your comment on acceleration from 1000 to 3000 rpm. One thing I can say about that is first gear is kind of useless because it shifts into second so soon. I'm really intrested to see how 3.42 gears will do because of that.
Hmmm so I just calculated that 425 horsepower at 3500 rpm is 637.5 ft-lbs of torque. That doesn't sound out of the realm of possibility.
AWWWWESOME, MAN!!!
And here I was happy tonight for seeing another 20PSI from my ATT. Ha!
Oh hey you should be happy!! I bet you could out tow me with how you are set up right now. 20psi with an ATT is nothing to sniff at. In fact that's why I want to try a larger turbine on my truck so I can have less restriction in the system and flow more air. So I may end up at a number more like 20psi when I'm done but actually flowing more air. Or maybe not - won't know til I try it!
