Goose57
Thanks Will that’s very interesting. I am curious I’ll check it out.Tons of people did mess with the rear cooling ports. Tons of problems.
Gm tried as well and did every conceivable combo and return location including reverse flows. It shifts the problem to other parts of the cylinders and or heads.
After spending many millions of dollars they came up with the balanced flow waterpump & system. The current pump is the 4th version. GM is all about the simple fix for cost reasons- if the “rear head cooling kits” worked - they would have done it . I worked for the company that was contracted out to GM in the process when they found the solution. The new pump, dual stat crossover with bypass restrictor fitting to equal out the flow and limit volume returning to the engine while minimizing cavitation in the pump. A full bypass thermostat is better but they already had the dual in manufacture mode so stayed with it. Heavy RVs and emergency generators got the blockoff crossovers.
Just type balanced flow in the search and you can read for weeks to learn it all.
